Front end loader tilt mal-function
baron
09-22-2001 20:39:18
My tilt on the front end loader has started to droop. It won't hold up like before. Have I blown out a check valve in the control valve or something? No apparent leaks any where. I think I may have harmed it pushing dirt in the tilt position. Thanks for any input.
Jim K
09-23-2001 06:07:15
 Re: Front end loader tilt mal-function in reply to baron, 09-22-2001 20:39:18
Hi Baron Typical first time tractor owner screwup
I know because I did the same thing. Do not push dirt with the bucket tilted down. You popped the rubber or nylon seals on the piston itself inside the cylinder, on one or both cylinders.Finding wich one is the fun part. Try working the tilt on the bucket while you or someone else watches the cylinders. one will seem like it is lasy or being worked by the other. if that don't work try pulling one pin on one bucket cylinder and you will find that one cylinder will work the bucket harder than the other. Good luck Jim K
