Jub axle nut
bay734
11-28-2006 15:30:20
I tightened the nut to 450, however the wheels clunk or make a cracking noise when I let out the clutch.What is happening?
octave
11-30-2006 15:53:15
 Re: Jub axle nut in reply to bay734, 11-28-2006 15:30:20
450 torque & still have clunk could be dad hub , ware on the taper on the axle shaft you need a good hub & Axle spline or it will Not work no matter how tight you get it
CNESLER
11-29-2006 04:43:02
When the hubs get some wear they will rub on the brake springs causing funny noise
CNESLER
Dell (WA)
11-29-2006 00:10:44
bay734..... ..no matter HOW TIGHT you honk on them Jubie axle nuts (and 450ft/lbs it the right number) iff'n yer splined hub splines are worn they NEVER TIGHTEN and they will clunk. You doubt? Try shaking the top of yer BIG AG-BAR tire sidewize and WATCH the axle-nut. Isn't that amazing? NEW HUBS $50 (cheap)..... ..Dell
