Order Ford 3000 Parts Online
ford 3000 that wont crank or turn over
ahvw8
12-01-2006 03:41:01
the other day i had left my 3000 ford in our back pasture, left the key on and the thing was dead in a day or two, went over with my truck and was going to jump it off, went over to crank tractor and the jumper cables just sparked, sence then i have hooked the cables up properly and the tractor will still not turn over or crank, any suggestions on areas to start in are appricated...
thanks in advance, keith
JK-NY
12-02-2006 06:32:01
 Re: ford 3000 that wont crank or turn over in reply to ahvw8, 12-01-2006 03:41:01
Try another battery, charge up the tractor battery or tow start it if you have another tractor to pull it with. The battery needs a good full charge put into it. Or like others said leave the jumpers hooked up for awhile before you try starting it.
maplehillfrm,pat
12-01-2006 15:11:32
did you try jumper around the solenoid ,, you can use a pair of pliers and touch the 2 big nuts at the same time,, if it starts you need a new solenoid or a key switch,, hope that helps,,
RodInNS
12-01-2006 07:11:21
Your average set of 4 ga booster cables won't turn that engine when it's own battery is dead. Hook the cables up, and make sure you've got a good spark (connection), and then let the truck run and boost it for 20 minutes or so. Then try starting it. It'll probably go then. Been down this road many times.... Make certain you've got good connections. HTH.
Rod
Tx Jim
12-01-2006 04:29:28
It's my experience if battery is really dead one has to leave jumper cables on for a while before my 3000 would start. I got to where I'd just pull start it if battery was down. Tx Jim
ahvyw8
12-01-2006 04:21:45
thanks for the quick responce
guest
12-01-2006 04:13:01
If it turned over yesterday and you
just left the key on the worst you can
do is burn the coil or resistor if the
points were in the closed position.
Try turning the engine with a crank
or rock it in 3rd geer.
Maybe it is in geer?
Starter should turn with a jump directly
to the starter, not
to the battery.
ahvyw8
12-01-2006 04:20:22
 Re: ford 3000 that wont crank or turn over in reply to guest, 12-01-2006 04:13:01
i failed to mention that the first time i hade the jumper cables on the tractor i had them reveresed
souNdguy
12-01-2006 10:39:12
 Re: ford 3000 that wont crank or turn over in reply to ahvyw8, 12-01-2006 04:20:22
I hope it didn't have an alternator.. if it did.. you will likely need to get a new one. heck.. even with a genny.. you may have smoked a 40$ regulator..e tc.
Soundguy
ahvyw8
12-01-2006 04:24:14
also failed to mention its a diesel
Jerry Cent. Mi.
12-01-2006 06:55:15
 Re: ford 3000 that wont crank or turn over in reply to ahvyw8, 12-01-2006 04:24:14
This is stupid but is it in neutral?
ahvyw8
12-01-2006 12:21:51
 Re: ford 3000 that wont crank or turn over in reply to Jerry Cent. Mi., 12-01-2006 06:55:15
yes i had tried all the normal stuff, batt con. shifter in neutral h/l in neutral, clean terminals, i'm going to try pulling it off when i get some help
thanks for all the input, keith
phil lowe
12-01-2006 15:22:22
 Re: ford 3000 that wont crank or turn over in reply to ahvyw8, 12-01-2006 12:21:51
my gas one did this a couple times and after jumping the solinoid few times to start it .It wouldn't strt and then turned wire nut on solinoid and she started right up ..guess first make sure battery got full chage ,then make sure all wire connections are tight /not corroded and not making good contact ..Mine was fine one day and appeared to go bad overnight too ,but could just be bad wire connection >I won't add any more as I'd be asking for help after that point myself:/[
