Snow blade attachment?
brad_bb
12-04-2006 10:47:47
Given the season and the fact that my 1955 Ford 960 restoration is nearly done, I was wondering if a snow plow/blade attachment was available from Ford originally for my tractor? Does anyone have any information if one was available? It would be the second most useful attachment next to my mower deck and post hole digger. If there was one, pics would be great. I"ve seen too many improvised loaders and blades that don"t work well. If I do decide to make one, I want to do it correctly and look like it could have been original equipment. Or maybe I can find an original unit to restore?
Dan Robertson
12-05-2006 04:53:49
 Re: Snow blade attachment? in reply to brad_bb, 12-04-2006 10:47:47
Try this link for more pics. Dan
Dan Robertson
12-05-2006 04:48:13
third party image
This is a factory blade designed to fit the 600- 801- early 4000 series tractors. I have never seen one that fits the 700 or 900 series Fords. Would take a much different mount to attach to tractor.
brad_bb
12-05-2006 11:01:12
 Re: Snow blade attachment? in reply to Dan Robertson, 12-05-2006 04:48:13
Thank you Dan. Considering the mounting and the fact that a wide front end is probably more laterally stable when snow plowing, perhaps a rear mounted blade is a better choice. The mounting is the same. Where would I look to find a 3pt mounted blade?
Dan Robertson
12-05-2006 14:48:50
 Re: Snow blade attachment? in reply to brad_bb, 12-05-2006 11:01:12
About any farm supply store, or tractor/implement dealer would likely have 3 pt. implements including rear blades. You can buy light duty blades all the way up to heavy duty, and with remote hyd cylinders for control. Prices start in the $200 range. Dan R.
jhill52
12-04-2006 11:54:56
Ford made them for 600s and 800s. I don't know of one made specifically for a 900 series. They attached with a bracket that bolted to the bottom of the trans case and the front loader monunt. I don't think they would work on you tractor because the belly is higher off the ground and the front of the frame is different.
That said I built on that was a copy of the Ford and it was easy to do and worked good. You would need to design a sub frame for the tractor that supported the blade at the correct angle. I encourage you to build your own.
brad_bb
12-04-2006 15:03:52
 Re: Snow blade attachment? in reply to jhill52, 12-04-2006 11:54:56
Do you have any pics you could email me?
Thanks.
jhill52
12-04-2006 17:50:06
 Re: Snow blade attachment? in reply to brad_bb, 12-04-2006 15:03:52
Unfortunately I don't and I don't have that plow anymore. DO a site serch for "dan robertson snowblade" on this site there are a couple pictures of his and Bill Oakes with Ford factory blades on them.
Jerry
