Order Ford NAA Parts Online
Jubilee Fuel Leak
Bob May35
12-06-2006 11:01:09
I have a Jubilee with Fuel Sediment Bowl that leaks very badly.
I have replaced the whole unit several times but I still have a couple of problems with it. First, The valve stem does a poor job of shutting off the fuel flow. Second,and worst of all the gasket at the top of the bowl leaks very badly. I have replaced the bowl and have replaced the gasket at least a dozen times using both the neporene and cork gaskets.I have been able to stop the leak for short periods of time but it will usually reappear in a few hours or days at best. I have stopped it temporary by loosen the base and twisting the bowl around on the gasket and then re-tighting the base. When I replace the gasket I can usually stop the leak until I add more fuel or the weather changes.
I have even considered trying to take the bowl and off and adding a in-line filter.
If anyone has any suggestions as how I can end this annoyance it would be appreciated!
Thanks
souNdguy
12-06-2006 11:12:25
 Re: Jubilee Fuel Leak in reply to Bob May35, 12-06-2006 11:01:09
Check to make sur ethe packing nut is not loose ont he valve stem.. most of them are shipped very loose.
I've had good luck using THICK gasket paper or the neophrene oring.. just takes an exactor knife and a pattern .
Soundguy
Jerry Cent. Mi.
12-06-2006 12:53:29
 Re: Jubilee Fuel Leak in reply to souNdguy, 12-06-2006 11:12:25
I had the same problem with one bought at TSC.
