What is it ??
8n2
12-11-2006 17:37:32
I have an 8N Ford tractor 1950 model that has a big knob on the dash that runs a cable going into the bell housing. The cable runs into a box attached to the wall between the bellhousing and the transmission. Does anyone know what this is ???
jimNCal
12-11-2006 19:55:27
 Re: What is it ?? in reply to 8n2, 12-11-2006 17:37:32
PROBABLY a (common)Sherman 'Step-UP'(overdrive) but if you're a REALLY luck sort, it'll be a(RARE) Step-DOWN(UNDERdrive) and worth big buck$$.
jim
Jerry Marks
12-11-2006 19:53:01
Go to John Smith's 8N Tractor site and you will find everything you need to know about your Sherman auxillary transmission. If your cable is frozen inside the casing, soak it in PB Blaster to free it up. New cables are in excess of $100, so if you can save your old one, you'll be ahead of the game.
Jerry
souNdguy
12-11-2006 17:57:43
Cable operated sherman step up tranny probably.
Soundguy
9n1411
12-11-2006 17:57:17
Sherman OD
