Order Ford 3000 Parts Online
3000 OR 3400
ANTHONY WALL
12-20-2006 20:06:59
i have owned this for years but really dont know what it is.it has a solid steel front axle and the whole front end is approx 3/4 inch steel,very hevy duty built tractor.7b23c on top line 35012c on second line,and c173267 7d27 on last line.i think it is a 1967 3000 or 3400.it is a diesel industrail live 540 with 8 speed trans.what is the difference between a 3000 and 3400.also waht brand service manuel is best
octave
12-21-2006 15:22:56
 Re: 3000 OR 3400 in reply to ANTHONY WALL, 12-20-2006 20:06:59
Anthony The 3400 Is the industrial version of the 3000 ag tractor.
heavy front axle for loader work.
the front axle on the 3400 would be arched
non adjustable with a steering cylinder on each side like the 3000 ,3000 steering cylinder had a 1/2 inch shaft 3400 used a steering cylinder with 5/8 shaft. 3400 had more transmisson options.
the 3000 was replaced by the 3600..
industrial version of the 3600 was the 335.
Ultradog MN
12-21-2006 17:27:53
 Re: 3000 OR 3400 in reply to octave, 12-21-2006 15:22:56
Correct!
3400 also had cast iron oil pan and 3000 just the regular tin one.
sotxbill
12-21-2006 09:33:54
you have a 3500... with the extra extra heavy duty front axle and front grill.. this model was usually used for backhoes and frontend loaders.. it could be equipped with many different transmissions and often did not have a pto or 3 pt lift due to other applications...
it can however have the standard 8 speed trans and pto and 3 pt lift makeing it a very very heavy duty farm tractor..... . and these are excellent for mounting front end loaders on becuase you cannot damage the front axles with the extra weight...
later these models were called the 335s..
hth... bill
sotxbill
12-21-2006 09:33:42
hth... bill
hvw
12-21-2006 06:44:44
I can't help you with the tractor ID but I can with the manual. Spring for the hundred bucks or so and get the three volume offical Ford manual. Well worth the price on your first repair. You can buy it from this site or New Holland.
