Order Ford 640 Parts Online
640 Military
Bill Nederhood
01-07-2007 15:48:55
I have owned this 1957 640 only a few weeks and need to learn a little more about it. At one time it was yellow and is now blue, I'm pretty sure it is supposed to be red. My real question is I found a tag on the plow frame from the army corps of engineers. Can I tell if this has been owned by the military in anyway? Or else I'm thinking just the front blade was. Also does this make a big difference in the sell price with the front blade and 1000lbs. worth of pie weights?
Lumpy
01-07-2007 19:10:16
 Re: 640 Military in reply to Bill Nederhood, 01-07-2007 15:48:55
The pie weights, if the set is complete, can be worth between $350.00 and $500.00 depending on which set you have. As far as the front blade, the value of it depends on the manufacturer. $300.00 and up is very common for a blade that is in very good condition. Does it have a hyd cylinder to raise and lower? Where are you located? I would be interested in the blade depending on where you are located and if you want to sell it. My email is open if you want to send photos. Thanks!
