Tool for PTO shaft??
brad_bb
01-11-2007 13:44:24
I want to dissassemble the PTO shaft for my 55 960. It had one large snapring for the OD of the bearing. That was no problem to remove. There is also a snap ring on the shaft for the ID of the bearing/hub. It does not have holes for snap ring plier. It just has two beveled ends towards the ID. It is also slightly recessed in the hub. Are there special pliers made for removeing this type of snap ring? I have been looking in the Snap-On catalog but no luck.
paul
01-12-2007 23:00:10
 Re: Tool for PTO shaft?? in reply to brad_bb, 01-11-2007 13:44:24
Have not worked on that part, but have worked with those type of snap rings. 2 screwdrivers seemed to be the specialty tools everyone uses?
--->Paul
Brad_bb
01-13-2007 06:58:13
 Re: Tool for PTO shaft?? in reply to paul, 01-12-2007 23:00:10
No, Screwdrivers won"t work. Too stiff a snap ring and no grip surface. They are reversed beveled.
I"m going to take the Cornwell page with me to the snap-on guy and see if he has the right set,
Thanks all, Brad
CENTAUR
01-11-2007 15:37:34
There are three others that sell the same tools,as snap-on made by the same manufacturer.They are MAC & MATCO & CORNWELL.If you go to CAT.page 230 0n WWW.CORNWELLTOOLS.com TOOL #WK-g705.WK stands for the MFD. CENTAUR
dan hill
01-11-2007 14:56:00
There is a tool for these rings.Ive used mine for transmission work for many years.It came from sears, has flat jaws that are Knurled on the surface.
