Ford 4 cyl engine ID ?
960
01-13-2007 16:08:07
A seller has a Ford 4 cyl. engine with ID of conn 6015J. What size is it? It is red with no hyd. pump and looks to be a stationary frame. It has a 6 blade fan and a fuel pump. It is gas. Thank you for any help.
JK-Mi
01-15-2007 06:50:26
 Re: Ford 4 cyl engine ID ? in reply to 960, 01-13-2007 16:08:07
All I can tell you about the part number CONN-6015-J is that it is a 1960 number. The "C" is defined as "6" and the "0" is the number zero. The base part number "6015" probably refers to the casting on which it is found. All numbers in the 6000-6999 range are basic engine parts.
