1710 engine
bflem
01-22-2007 17:14:32
What should the pounds of compression be on a 1710 ford cylinder. I can not find it anywhere.
bflem
01-22-2007 19:27:47
 Re: 1710 engine in reply to bflem, 01-22-2007 17:14:32
I have the compression ratio ,what I what is to check with a gauge on each cylinder for the correct amount pressure (example 130 lbs)
RodInNS
01-22-2007 20:09:48
 Re: 1710 engine in reply to bflem, 01-22-2007 19:27:47
I'd have to check the book (which I don't have), but I'd suspect it's 400 psi+. The best I could get would be for a 1920, which isn't necessairly more relevant than the number I just gave... HTH.
Rod
Blairsville Bud
01-22-2007 19:04:05
The Compression is 23 to 1. Engine Model H843. 85.2 cu in.Rated speed 2700 RPM
