Order Ford NAA Parts Online
Naa carb-cracked bowl
Anthony Bettis
01-29-2007 05:35:22
I have a 54 naa with about a 3/4'' crack in the bowl.Does anyone know if I can braze this,or if not where can I get a good rebuildable carb.
Dave H (NY)
01-30-2007 16:10:19
 Re: Naa carb-cracked bowl in reply to Anthony Bettis, 01-29-2007 05:35:22
E-mail Rod Rippee at rip@charterinternet.com he will have what you need
Jerry/MT
01-29-2007 20:03:44
A repair for a cracked fuel bowl is a crap shoot. Might work, most likely won't. Look around for a used one or get a rebuilt one. They're around a $100. Don't understand how anybody could crack one. They look stout enough to use as a jacking point on the tractor!
Bob
01-30-2007 08:41:00
 Re: Naa carb-cracked bowl in reply to Jerry/MT, 01-29-2007 20:03:44
The most common way they crack is when they get water in the carb, and it freezes. Does QUITE a number on the float, too!
Anthony Bettis
01-30-2007 06:25:40
Jerry Id love to find 1 for a $100,tell me where?
Jerry/MT
01-30-2007 13:54:27
 Re: Naa carb-cracked bowl in reply to Anthony Bettis, 01-30-2007 06:25:40
Have you looked on ebay? I've seen Marvel-Schebler's there for on the order of $100. This site has a rebuilt carb for an NAA for $143 + core and a new one for about $190.
Anthony Bettis
01-29-2007 13:06:01
old, ck and see if you dont mind,I already have the kit.I may have to break down and buy a rebuilt but I was trying to get by if possible.
Dan I saw that 1 on e-bay,it looks rought but if the bowls sound it might work.
Soundguy I thought about jb weld but didnt know it was gas proof.
Dan
01-29-2007 18:12:25
 Re: Naa carb-cracked bowl in reply to Anthony Bettis, 01-29-2007 13:06:01
JB Weld is 100% gas proof once cured. I called them up directly for this question as I used it to patch the fuel tank on my 52 8N. Worked fine for the year I owned it and I worked it hard.
Dan
souNdguy
01-29-2007 10:59:58
I'd solder it before i brazed it.
heck.. clean it with carb cleaner and jb weld it. once cured, jb weld is gas proof.
Best bet is to just get a new carb... and keep that one as a spair.
Soundguy
old
01-29-2007 08:37:37
I've seen more then one that was brazed up, but on about 75% of them it warped the carb enough to cause a lot of other problems. I've seen where they wouldn't bolt back togeather correctly and or the float would hang up. I'd check with some place like valuebilt and buy a rebuilt one from them or keep you eyes open for one. I might even have what you need but I would have to do some checking to be sure. Most M/S carbs are the same and theres only 3 or 4 bowl sizes on them its just the jets that are differant
Dan
01-29-2007 08:20:25
There is one for cheap right now on ebay. Click on the link below.
Good luck,
Dan
