Order Ford 600 Parts Online
3600 front end
TomB
10-05-2001 03:55:09
Hi; I think I may have messed up. Picked up about 2200 lbs with my loader the other day and now I notice both front wheels point in opposite directions about 5 degrees (out)maybe even more. Must admit I never really looked before and don't know if I created the problem or if it was their before. Also the camber on one wheel lays the tire about a 1/2" from the steering support post while the other is about 3". There is enough room on the adjustment screws to correct the wheels pointing out but all the take up one one will probably be used. Don't see any thing bent and the pistons on the assisted steering seem to work equally. Any thoughts will be appreciated. tomb
Klaus
10-05-2001 09:28:59
 Re: 3600 front end in reply to TomB, 10-05-2001 03:55:09
Lift your front wheels off the ground (with loader, etc...) and see how loose the spindles are. Probably the spindle bushings and/or spindles are really worn and need to be replaced. I suspect that this didn't happen all at once.
Shawn
10-06-2001 19:31:27
 Re: Re: 3600 front end in reply to Klaus, 10-05-2001 09:28:59
Check your axle support too. You can crack this casting if you lift too much.
Tomb
10-10-2001 05:35:04
 Re: Re: Re: 3600 front end in reply to Shawn, 10-06-2001 19:31:27
Thanks for the thoughts. Definetly appears to be the ball joints, can't see any cracks in the axle support TomB
