Order Ford 960 Parts Online
960 power steering timing
Bob Thompson
01-29-2007 12:41:41
I have a 960 tricycle that the power steering did not work. I rebuilt the cylinder and now just as soon as the motor turns the wheels lock to the left. I was told by a dealer that the power steering had to be timed. Does anyone know how to do this, or is it really necessary
Joe(TX)
02-01-2007 06:00:56
 Re: 960 power steering timing in reply to Bob Thompson, 01-29-2007 12:41:41
There is no timing involved with a row crop power steering. And no lines to reverse. I most likely has air trapped or the control valve is assembled wrong.
Bob Thompson
02-01-2007 12:55:01
 Re: 960 power steering timing in reply to Joe(TX), 02-01-2007 06:00:56
I'm not sure about the relief valve or the hoses. I'll need to check and see if either one helps.
Richard H.
02-01-2007 06:29:42
Isn"t there a relief valve in the pump,? sounds like his may be stuck open or do I mean closed...
Larry W Blum Jr
01-30-2007 01:36:39
Could you possibly have the lines reversed? This sounds like what happens on a car when the lines are reversed.
