acid cleaning a cast iron carb
Anthony Bettis
01-31-2007 13:37:10
I was reading the archives looking for things re. my carb rebuilb prior to posting a question,and someone mentioned using an acid bath to clean cast carbs cause the regular stuff wouldnt clean well enough.We vatted my NAA carb and its still pretty nasty.What acid solution would you use,a dulited muratic or what?
DonCam
02-01-2007 06:54:50
 Re: acid cleaning a cast iron carb in reply to Anthony Bettis, 01-31-2007 13:37:10
I have used phosphoric acid to clean steel and cast iron parts it does a good job. What I do to neutralize it is to spray some cheap walmart brand yellow can easy off on it after the acid clean and give it a good flush with water. THe rust isn't a big of a factor after that.
CENTAUR
01-31-2007 14:36:25
To prevent rust and keeping it looking like new,mix used motor oil and cleaning solvent and dip the casting into it and the result will look like a new casting for a long time as the cast iron is porous.CENTAUR
Grampa Leon
01-31-2007 14:12:24
I always muriatic acid full strengh,with gloves,
after using rust is a big problem,especially on
cast,also it will eat up aluminum.
