Order Ford 4000 Parts Online
1964 Ford 4000 will not start, think injector pump not pumping
Tim Gant
10-07-2001 15:31:27
Can anyone tell me if the injector pump can be rebuilt on a 1964 Ford 4000 4 cylinder diesel and if so where can I get the information on how to rebuild it. I am unfimiliar with diesel engines.
Thanks in advance for any help
Tim Gant
Jason
10-07-2001 20:01:09
 Re: 1964 Ford 4000 will not start, think injector pump not pumping in reply to Tim Gant, 10-07-2001 15:31:27
I'm not familiar with the 4000, but I have a lot of experience with diesels. I would not go right to the injector pump yet. First, you want to eliminate everything simple. Change the fuel filter(s), make sure you have good flow to your lift pump (not injector pump, but lift pump) and your fuel filters. You should also bleed all the air out of the system. You might want a manual to help you along. But like I said, try the simple things first.
P.S. An injector pump is not something you rebuild yourself.
