Order Ford 3000 Parts Online
3000 ford hydraulics problem
billy carr
02-19-2007 18:24:40
we had very cold weather &snow used tractor to remove snow . hydraulics worked after long time warm up . the pump started leaking replaced gasket . now hydraulics not working .i took plug out of pump to bleed air out .still not working . i put in two gal. of fluid.i am using 80 90 weight oil is that right? help
RodInNS
02-21-2007 08:19:09
 Re: 3000 ford hydraulics problem in reply to billy carr, 02-19-2007 18:24:40
Drain, and refill with 134D or it's equivelant, and hope you didn't cook the pump.
Rod
billy carr
02-22-2007 14:31:44
 Re: 3000 ford hydraulics problem in reply to RodInNS, 02-21-2007 08:19:09
thanks for everyones help having pump rebuilt
souNdguy
02-20-2007 06:30:48
Say 'hello' to pump cavitation. That pump was designed for a light weight oil.. like a UTF fluid, or an aw32/46 hyd oil.. not rear end 85/140.. or 90w oil.
I hope you havn't smoke dit already.. especially in this cold weather.
Go grab some utf oil and a copy of the MANUAL for that tractor before you damage something.
Soundguy
Ultradog MN
02-19-2007 21:26:47
How cold is it and how much water do you have in the rear end?
Cold + water = ice crystals in the pickup tube in the rear end.
I would bring it inside and thaw it out somehow.
Overnight or longer!
Then drain the rear end and refill with 134D.
Let us know if that works.
awhtx
02-19-2007 18:46:48
You should have 134D fluid in the hydraulics. 80 or 90 wt oil is way too thick.
