Order Ford NAA Parts Online
NAA distributor
Bob
02-19-2007 19:11:56
I need to confirm the rotation of a NAA distributor is CW. (NO, it's NOT in the I&T Manual, and I have just the distributor, NO engine.)
Dave in Ms
02-20-2007 08:21:27
 Re: NAA distributor in reply to Bob, 02-19-2007 19:11:56
From the Owners Manual. HTH, Dave:
third party image
Dave in Ms
02-20-2007 08:25:36
 Re: NAA distributor in reply to Dave in Ms, 02-20-2007 08:21:27
Bob,
I forgot to tell you to look at the arrows on the cam. CW. Click the pic to enlarge.
Dave
Bob
02-20-2007 08:29:03
 Re: NAA distributor in reply to Dave in Ms, 02-20-2007 08:25:36
THANKS for taking the time to post that scan.
This turned out to be a REAL interesting deal... a CCW late 8N advance swapped into a CW NAA distributor.
It didn't work out very well!
CENTAUR
02-19-2007 19:22:43
The distributor rotates the same way that the advance mechanism advances when you grab the rotor and or the cam and see which way it goes.CENTAUR
Bob
02-19-2007 19:41:08
 Re: NAA distributor in reply to CENTAUR, 02-19-2007 19:22:43
Centaur,
Your CORRECT. Problem is, I'm dealing with a malfunctioning distributor.
I am checking out an NAA distributor for another poster, and it APPEARS the cam/advance mechanism has been swapped out for another, from a side-mount 8N.
I'm 99% certain I have figured out the problem... NAA distributor (which I'm almost certain turns CW) has advance mechanism from 8N (which DOES turn CCW) installed, causing coil to "fire" when rotor and high-tension terminals are NOT lined up. Not to mention RETARDING spark timing as speed increases, instead of ADVANCING it!
I thought confirming rotation would be a simple matter of opening the I&T manual for the NAA, but they thoughtfully omitted that simple, basic information.
