 Ok.. from what my bad eyes see here is what I think: 1, it apepars to be a 711 loader, as the lower support is not tapped for hyd sump. 2, it appears to have the 5.5" box, meaning that it was made for the x00 hundred and early x000 4 cyl tractors. 3, it appears that one of the brackets in the pile is what we here are calling a 'hip' bracket. it bolts to the left side bellhousing with 3 bolts, and has a 'nub' that engages the box on the loader, which you then put a pin or bolt thru to hold it on. 4, you are missing the front under axle bracket.. no biggie.. this can be 'torched' out of 1/2" plate, then drilled for 2 bolt holes, and a large hole for the front of the laoder frame 'toe' to engage. 5, you are missing the lower bracket that goes from the underside base of the loader to the underside of the tractor bellhousing... again.. no biggie.. this can be torched out of 3/8 plate and then drilled for the 2 bolt holes. Assuming that hip bracket is either homade.. or of a HD design I havn't seen, you should be good to go.. the 'hip' bracket is always the har one to track down.. the other 2 are flat stock 'torch' jobs if needed. Again.. only guessing about that hip bracket. if it were me.. I'd trailer my 860 up there and then ask to 'hold' that bracket and see if it matched up tot he holes on my bellhousing. Price? I seen em go for 50$, 150% and 350$. Depending on where you live.. sometimes they are more plentiful. down here in florida. they are 'extremly' rare.. I paid 350$ for mine.. it was a similar 711 with a 80% rusted out bucket, but was hyd dump.. etc., came witht he 'lower' bracket... I had to buy the hip and axle brackets. Now.. a couple of the other guys here.. like ultradog.. well.. he is tripping over them it seems... they just find there way to his palce all the time from what i hear ( i'm jealouse! ) On the loader frame. the seller indicates the frame number is 19-209, that indicates that it is the mechanical dump version o fthe 711 9 19-276 would be the hyd dump ver of the 711 ).. in any case.. the specs on that laoder are as follows: 1000# lift to full height 2500# breakaway lift About 117" from grounf to bucket floor at full lift, and about 5" below ground level and full drop... those numbers were for the 19-276 hyd model.. but the mech deump model will be similar.. etc. Here's what mine looked like for 350$.. I had to weld a new floor into the bucket... keep us posted on what yuo decide, and if you get it. If i lived in tx I'd be bidding on it! Soundguy
