Order Ford 4500 Parts Online
4500 power steering adjustment
chuck
10-08-2001 16:26:24
My 4500 TBL will steering is a little week but it
also turns to the right ok,I have to lift the
front up with the bucket to turn it to the left. I dont have a manual & local dosent offer any
parts or info on the older 1969-70 model 4500.Any
help with what to check,adjust or where to find parts would be a big help.
Texadian
10-12-2001 11:19:48
 Re: 4500 power steering adjustment in reply to chuck, 10-08-2001 16:26:24
Chuck, Nathan is right, the power steering control valve is mounted on top the power steering cylinder, as the linkage wears, the valve may not move far enough to direct oil into the cylinder to move it. The arm that moves the valve has a pin that extends down into a large hole in the center steering arm to limit its movement. It's a one inch pin in a one and a quarter inch hole. The linkage to the control valve needs to be adjusted so the valve is centered when the limit pin is centered in its hole.
Nathan(GA)
10-08-2001 20:02:49
There's a little valve on top of the steering cylinder that may be sticking or have some loose play. It's up front under the radiator, in a heck of a place to work on. I need to break down and fix mine but I'm still fighting it. I don't use it that often.
