Blow By
Air Force One
03-04-2007 06:52:15
On my 850, right side, there is a blow by on the valve cover. It seems to be letting a little oil out and gets on the engine. Does this blow by with the small opening in it...should it be pointing down or up? Thanks
GVS
03-04-2007 15:12:20
 Re: Blow By in reply to Air Force One, 03-04-2007 06:52:15
up
GlenIdaho
03-04-2007 13:26:35
Air One; I don't know that it makes a difference as to which way it is pointed. On my 850 the vent cap was pointed to the rear of the engine. You should have a filter within the housing that catches any oil or dirt. Does it need to be cleaned? Just a thought and hope it helps.
Air Force One
03-04-2007 17:26:35
 Re: Blow By in reply to GlenIdaho, 03-04-2007 13:26:35
Yes..it has a screen in the cap. I will try it up to see what happens...thanks again..
GlenIdaho
03-04-2007 19:47:27
 Re: Blow By in reply to Air Force One, 03-04-2007 17:26:35
Air One; there is supposed to be more that just a screen in the cap. It is like the filter found in the crankcase breather cap.
