Order Ford 2000 Parts Online
4 cyl. 2000 hydraulics question ...
JAE-Tx
10-10-2001 07:14:30
I have an early 2000 (4 cyl. gas), and recently had the hydraulics rebuilt, but I've had a problem ever since.
With a heavy load, the lift will raise and lower normally for a short time, then it will only lift part-way up (maybe 3/4 of the way) and begins to "hiccup".
What am I looking for, problem-wise?
The lift will still get the job done, but it's not quite right. Any suggestions are appreciated.
walt
10-10-2001 15:15:07
 Re: 4 cyl. 2000 hydraulics question ... in reply to JAE-Tx, 10-10-2001 07:14:30
Maybe just some air in the lines. Look at the pump, and crank the tractor. Pressurize, on the the pump should be a bleeder bolt/screw. Loosen slowly air/fluid should come out. Wear glasses/goggles for eye protection.
Mike
10-10-2001 09:40:53
Do you have your hydralic control lever in the "draft" or the "control" position?
