Need PTO snap ring pliers help!
Brad_bb
03-05-2007 06:37:01
I"m close to finishing my 55 ford 960. I want to change the PTO shaft bearing, but there is a external snap ring on the shaft that has a back wards bevel on the ends. This is not a conventional snap ring with eyelets. This ring is also partially shrouded under the bearing cup. Does anyone have the right tool for this. If so, what brand and part number please. I visited a snap on dealer on Saturday and he was not persoanlly familiar with this type of snap ring. The ends just bevel back to the inside. So I need snap ring pliers that will grab the ends and spread it open - from the side. thanks,Brad
Jim K
03-06-2007 12:40:47
 Re: Need PTO snap ring pliers help! in reply to Brad_bb, 03-05-2007 06:37:01
Don't buy the harbor freight ones I have a set and they are made out of a non hardened cheap Chinese bed springs. with snap ring pliers you don't want to skimp they may be a small not often utilized tool but they do a tough job.
And it $uck$ when they don't work properly.
jiskies2
03-05-2007 23:38:10
i made them out of needle-nose pliers as a make do setup .
jeff
svDan
03-05-2007 14:55:46
snap on #PR16, that should get it
Brad_bb
03-06-2007 07:23:23
 Re: Need PTO snap ring pliers help! in reply to svDan, 03-05-2007 14:55:46
svDan,
I looked up a picture on Snap on"s website. Those look right! Rock on, brother! Thanks! Nothing better than finding the right tool for the job.
Dave H (NY)
03-05-2007 14:05:47
When I have had to take them out I buy a new replacement snap ring because I always stretch them too far.
Oliver in SC
03-05-2007 09:44:39
Try your local auto parts store. I bought a snap ring plier kit at NAPA that had different types of ends you could insert into the pliers. Straight, curved, 45 and 90 degree angle tips were included.
