Order Ford 600 Parts Online
Ford 600 Serial Number
Bill Newhart
03-05-2007 07:10:51
People, Ford 600 serial number on my project tractor(It is a 640) doesn"t corrrespond to any serial number I can find. I think somebody changed Ford engines-I do know they left off a lot of parts. All I can find is the number 310905 on the right side of the engine (distributer side) and on the other side OF16 2. Appreciate it if any body can point me in the right direction to identify this engine (tractor year?) Thanks, Bill N
Bill Newhart
03-05-2007 18:40:31
 Re: Ford 600 Serial Number in reply to Bill Newhart, 03-05-2007 07:10:51
Neath the dirt and grime I found the number right where you all said it was. Thank you guys for the help.
Bill
Jim.UT
03-05-2007 14:30:52
third party image
The number on the right side is a casting number. I don't have engine casting number info memorized, but it seems like that's probably a number for a 601 engine rather than a 600.
Here's a photo of where the s/n and model number are stamped.
Fordfarmer
03-05-2007 07:23:40
Serial (and model) numbers on 600's (all hundred series) are stamped on a flat near the front of the transmission, on the left side, just above and to the rear of the starter. May be hard to find/read, as they are often shallow stamps, or filled with paint or grime.
