Thanks for the comments, everyone. Do I understand correctly this isn't a freeze plug but rather a product of the casting process? My New Holland dealer called it a freeze plug; hence my terminology. I'm sorry I wasn't clear enough in my original post. This is now the THIRD time this plug has failed since about 2000. My fear is that something has happened to hole in the water jacket the plug seats into; otherwise they would not be failing with such regularity. As I pointed out, I run this tractor on a strictly 50/50 anti-freeze water mixture so rust is not likely the culprit. I am not prepared to simply have the plug replaced according to the usual shop procedure. One can't simply repeat the same process over and over and somehow expect a different result! (Insert your own Iraq joke here.) Obviously, the correct solution is to replace the water jacket. I'm still in denial about this; I hope to pass on through bargaining and acceptance, but in the meantime... If this was only a little coolant leak I wouldn't sweat it so much; but this business of having to take the tractor to shop every few years so they can split it and put in a new clutch is not acceptable.
