1715 Ford
A/C Boy
03-14-2007 20:10:12
I have a 1715 ford 3 cyl diesel. Had nothing but trouble with the clutch. It is stuck I think. It stays in gear all the time. I could see alot of water inside the bell housing. Come to find out the drain hole was stop up. Does anyone know of anything I could beside taking the tractor apart. I think it is a junk ford made in j-pan. is the first problem.
TomTX
03-15-2007 05:15:41
 Re: 1715 Ford in reply to A/C Boy , 03-14-2007 20:10:12
If you have the regular USA sold version of that little tractor, it is VERY high quality Japan product. If we could build with that level of quality, then Ford wouldn't be going broke, Toyota wouldn't be being outselling GM etc. Your bad mouthing an excellent product that has probably been mistreated by operators without Operator Manual, Repair Manual, Parts Manual, etc. Tom
RickB
03-15-2007 03:24:14
Where do you think A/C's junk compacts came from, boy? Next time read the manual and block the pedal down when the tractor sits. And use it once in a while. Did you buy it to use it or just let it sit out in the weather. Plan on splitting the tractor to fix it. If the bellhousing had that much water in it it probably won't free up any other way before you wreck something or kill yourself.
