another loader question
jr150hp
03-18-2007 07:02:58
is a 702 a ford model loader and what year is it and will it fit a 841 thanks
jr150hp
03-18-2007 13:37:22
 Re: another loader question in reply to jr150hp, 03-18-2007 07:02:58
it's a bit lighter duty thanks has anyone made one into a full hydro dump insted of a trip bucket ??
lonestarjeff
03-22-2007 19:02:51
 Re: another loader question in reply to jr150hp, 03-18-2007 13:37:22
Not sure this answers your question, but I converted my 701 loader to full hydraulic. Mine's installed on a MF165D. As budget permitted I added one bucket cylinder, then another. The front pump & 2-spool valve both came off ebay.
third party image
I have a set of forks to pick up 6x6 round bales, that's probably the most weight I use it for(1000#).
The research I did on the loader before I bought it said it will fit hundred-series tractors too.
Jeff
awhtx
03-18-2007 19:16:56
 I saw one at a farm eqpt auction.... in reply to jr150hp, 03-18-2007 13:37:22
yesterday that had been modified to hydraulic dump by adding 2 cylinders. Brackets for the cylinders had been welded to each side of the loader frame and to each side of the bucket. The frame had been altered to fit some tractor other than a Ford. None of the brackets to attach the loader to a Ford were included nor was the front pump included and it still sold for $600. I wouldn't have paid more than $200 for it and that would have been for the dual spool valve that was included.
Dave H (NY)
03-18-2007 12:01:21
I have a 720 and I believe it is the same as yours just newer. It will fit an 841 although it is a bit heavy for that tractor with the light front axel, just don't over load the machine.
