Order Ford NAA Parts Online
Jubilee hydraulics flush
bobeque
03-19-2007 03:31:55
What do you use to flush Jubilee hydraulics system? How do you flush the pump? thanks
souNdguy
03-19-2007 05:45:58
 Re: Jubilee hydraulics flush in reply to bobeque, 03-19-2007 03:31:55
Cheap fresh oil is the safest way to flush the pump. if you just want to flush the sump, you can run some diesel or kero or mineral spirits in there, let set a bit and then drain. If yuo want to get the small amount of stuff inthe pump lines and pump, turn ignition off and crank over while you have that diesel in the sump.. but dont start. then drain.. then refill with fresh oil.. then start.. make sure 3pt works.. if not.. check to see if pump needs to be bleed of air.
Soundguy
