ford 172 ci Diesel Rings and Rod bearings
Al M
03-20-2007 05:33:25
I have a 63 industrial 4040 . No history available.
Pistons are out and would like to know how to determine the right size rings and rod bearings
Thanks
john_bud
03-20-2007 19:33:45
 Re: ford 172 ci Diesel Rings and Rod bearings in reply to Al M, 03-20-2007 05:33:25
Easiest and most accurate way is to take it to a machine shop and have them measure it.
Other was is to use a bore gage and measure it yourself. Less High tech is to use a caliper and measure it in 5 spots across the diameter.
Given your question, my assumption is that you are not a skilled machinist. If that is correct, use the first method.
Oh, if it is a 4040, then it is younger than a 63. Probably a 61 or 62 as they changed the model to 4140 for the 63 model year.
jb
A l Milono
03-22-2007 13:44:46
 Re: ford 172 ci Diesel Rings and Rod bearings in reply to john_bud, 03-20-2007 19:33:45
Thanks! Took the rods pistons and bearings into Ocala Fl New Holland and they spent cosiderable time and were able to identify bearings rings and pistons as Standard original and combined with the 5 bore measurements got me me set up!
Thanks Again
