Order Ford 4000 Parts Online
Ford 4000
Arthur264
03-21-2007 13:25:29
Will the 134 cubic inch engine from a 1957 640 Ford bolt to the trans and work in a 60's Ford 4000 tractor?
Dean
03-21-2007 15:18:01
 Re: Ford 4000 in reply to Arthur264, 03-21-2007 13:25:29
Arthur:
Ford made two entirely different 2000s in the 1960s.
The 134 will bolt right into a 4 cylinder 2000 but the later 2000 with 3 cylinders is entirely different.
Dean
Arthur264
03-21-2007 17:10:09
 Re: Ford 4000 in reply to Dean, 03-21-2007 15:18:01
>>The 134 will bolt right into a 4 cylinder 2000<<
Thanks,but will it bolt right into a 1960's 4000 series?
Joe(TX)
03-21-2007 19:11:15
 Re: Ford 4000 in reply to Arthur264, 03-21-2007 17:10:09
You have to tell us 4000 it is. pre 65 or later.
Arthur264
03-21-2007 19:41:58
 Re: Ford 4000 in reply to Joe(TX), 03-21-2007 19:11:15
>>You have to tell us 4000 it is. pre 65 or later. <<
I don't know what year it is.
Dean
03-21-2007 17:27:27
Sorry, Arthur.
Substitute 4000 for 2000 into my previous post. The result is the same.
Dean
Arthur264
03-21-2007 18:49:39
 Re: Ford 4000 in reply to Dean, 03-21-2007 17:27:27
>>Substitute 4000 for 2000 into my previous post. The result is the same.<<
Ok,THANKS!
Dean
03-22-2007 04:00:42
 Re: Ford 4000 in reply to Arthur264, 03-21-2007 18:49:39
Arthur:
Though the 134 engine will bolt right into the 4 cylinder 4000, it produces a good 15 HP less than the late model 172 engine. You will end up with a heavy early model 2000 tractor.
I should have mentioned this last night but had very little time.
Dean
