174 Dieseil Pistons all cracked under top ring??
Al M
03-23-2007 05:49:28
I am rebuilding a 4040 and two of the old pistons have a large piece actually broken out between the top and second ring. The other two are cracked
under the top ring ..can anyone help with a possible explanation Thanks
TomTX
03-24-2007 06:02:13
 Re: 174 Dieseil Pistons all cracked under top ring in reply to Al M, 03-23-2007 05:49:28
Agree with the posters below. Sounds like you or the previous owner used ether (starting fluid) on it. Also the Perkins engines in MFs are very easy to break like this. Tom
john_bud
03-23-2007 20:54:14
You mean like this?
third party image
third party image
Caused by ether (starting fluid AKA the devils juice)
Or pulling a stuck engine at 25 mph then popping the clutch....
jb
I Likem All
03-23-2007 19:16:26
This site has the best price on 172 c. i. diesel pistons. ILM.
ron tepoel
03-23-2007 09:03:31
this is common, also, starting fluid can do this
Bern
03-23-2007 08:23:11
Ether
RodInNS
03-23-2007 06:19:39
Unless it had a run in with a large dose of ether, it's likeky just worn out. They get worn, the pistons get sloppy and start slapping. Things break. If the pump was turned up, that could contribute too.... but it probably wasn't on that model. Ether is a really common method of breaking pistons..... .
Rod
Al M
03-23-2007 05:52:04
 Re: 172 Diesel Pistons all cracked under top ring? in reply to Al M, 03-23-2007 05:49:28
Sorry it is a 172
