Rob - 1310 pump timing
Bern
03-26-2007 12:53:02
Rob,
Was out of town, just saw your message about the injection pump timing, which is now half-way down on page 2.
Assuming you got the right pump, and assuming that you're doing the spill timing process correctly, my guess is that the cam timing is a tooth off. Since you got it without a pump, it almost sounds like this engine has been apart recently. Whatever you do, don't mill the pump! Something else is wrong.
