Order Ford 4610 Parts Online
Ford 4610 Ignitions Switch
Ag Teacher
03-29-2007 19:12:44
The ignition switch quit working so I changed out the switch, careful to get wires back right, still will not start with ignition switch. Starts fine when I short out at the starter.
What should be the next thing to look at?
Thanks,
JJ
Jerry/MT
03-30-2007 15:27:41
 Re: Ford 4610 Ignitions Switch in reply to Ag Teacher, 03-29-2007 19:12:44
My 4610 requires a little jiggle of the hi/lo lever because I believe I have sticky safety switch.
richard in nz
03-30-2007 04:37:40
Check the continuity of the wire down to the starter. It should be white with a red tracer. It will go to the safty switch before going to the starter- they can fail. and I think there was a multi pin plug on the left side of the dash/fuel tank area which can give trouble.
Old Ford Mechanic
03-29-2007 19:23:06
I would check the wire going to the spade terminal on the solonoid switch and also the safety switch and the wiring to it.If it has a hi lo tranny try moving the shift lever back and forth with the key held in the start position.
Ag Teacher
03-30-2007 18:27:43
 Re: Ford 4610 Ignitions Switch in reply to Old Ford Mechanic, 03-29-2007 19:23:06
Thanks for the help. Along that same line. There are two wires going into the transmission right by the hi/lo lever. These wires are not hooked to anything. I just bought this tractor a few weeks ago and it was starting ok then. I have a fifth grader who is very interested in getting the lights all hooked up again. I am beginning to wander if he..... ..... That is why I was asking about the 2 wires.
