Removing Unloading valve plug
bp73
04-04-2007 11:08:21
Does anyone have a secret to removing the unloading valve plug on a 600 ford tractor hydraulics?
murn ga
04-04-2007 14:35:55
 Re: Removing Unloading valve plug in reply to bp73, 04-04-2007 11:08:21
Go to the other end of valve,you will see the hole for the valve. Use a flat end pilot punch or an old bolt and tap lightly on the valve, it should knock the plug out.
robil
04-04-2007 11:40:14
I did this on a jubilee. You must remove the unloading valve first by removing the screwed on cap at the one end, and then using a wooden dowel tap out the other cap end.
