One wire alternator
big1
04-04-2007 11:37:16
Have tried 2 one wire alternators on my 1954 NAA and both crank out 18+ volts. Battery will boil, any thoughts.
TJongbloedt
04-04-2007 17:34:41
 Re: One wire alternator in reply to big1, 04-04-2007 11:37:16
You alt. should put out more than 12 volts untill your battery is at a full charge. let it run and when your battery is charged it should read about 12.6 volts. New batteries come about 60%-70% charged I have used several one wire and have no trouble. Thay are great for tractors with mags now extra switches just a orignal kill button.
souNdguy
04-04-2007 11:51:21
Sounds like they are bad.. or are not really fully 1 wire jobs.. but 3 wire jobs that happen to self excite.. and have no reference for V at the # 2 pin..
Soundguy
old
04-04-2007 11:39:44
Yep you have found another reason the 1 wires don't work as well as the 3 wire set up does. If I where you I would go with the 3 wire type and be done with it. On all the 3 wire set ups I have done I have never had any problems
Obsession
04-05-2007 06:53:50
 Re: One wire alternator in reply to old, 04-04-2007 11:39:44
I agree with old. The 3 wire is the way to go.
Brian in MA
04-04-2007 13:45:47
What are the other 2 wires on a 3 wire set-up? I assume that this would use the original voltage regulator as opposed to a self regulated delco alternator?
old
04-04-2007 15:04:50
 Re: One wire alternator in reply to Brian in MA, 04-04-2007 13:45:47
The delco 10SI alternator has a built in regulator. From the little plug it has 2 wires one goes to the battery stud on the alternatro the other goes to the switched side of the ignition switch so thats why its called a 3 wire. From the battery stud you run a wire to the battery or other such place so you end up with a total of 3 wires
Brian in MA
04-05-2007 06:19:06
 Re: One wire alternator in reply to old, 04-04-2007 15:04:50
Thanks. So if I understand it correctly, when it is running, there is 12 volt power to all 3 wires? I believe I have one of these and it doesn't seem to be working at all and I wanted to be sure I am wiring it correctly.
Thanks for the help!
Keith-OR
04-05-2007 10:33:42
 Re: One wire alternator in reply to Brian in MA, 04-05-2007 06:19:06
Brian, the plug on the back of the Delco alternator is labeled #1 & #2. #2 is hooked to the large Bat terminal. #1 is hooked either to a diode, or charge indicator lamp(200ma@12V--#1815 lamp)..HTH
Keith & Shawn
Diagram from Bob M
third party image
Brina in MA
04-05-2007 12:48:56
 Re: One wire alternator in reply to Keith-OR, 04-05-2007 10:33:42
Thanks. Very helpful.
