Ford compact 1715
A/C BOY
04-11-2007 19:33:00
Well, I took my ford and had the clutch . pressure plate replace got it back and now the starter sounds different then when I took it up to the ford place. It was smooth and now sounds slow. Got any ideas what may have happen?
RoNofohio
04-12-2007 19:35:19
 Re: Ford compact 1715 in reply to A/C BOY, 04-11-2007 19:33:00
Just sounds like it may be a bad ground. Maybe just tightening the starter bolts might be enough. Also, check the ground cable from the battery to the chassis to make sure it is clean and tight.
