I took the control valve to the Ford/New Holland dealer, and they reassembled the control valve for me. They also sold me a repair manual which showed the correct assembly instructions. After reinstalling everything, my power steering is not working. Consultation with the dealership told me that I might have the nut above the bearings too tight, keeping the control valve from working. The manual says to "remove all play, and then back the nut off 1/6 turn before setting the nut with a punch in the Locator hole." How much tension should the bearings above the control valve have? I loosened the nut and did my best to lightly remove all up and down play on the steering shaft, and then back the nut off 1/6 of a turn. It still didn't work for me. I have been experimenting with different tension on the bearings (and control valve) for a couple of days, but have not found the combination which makes everything work properly. All help would be gratefully appreciated. Email help would also be welcome. dirtbike_smackover@yahoo.com Thanks for your replies so far, and thanks in advance for any more sent. Jim Cook
