Order Ford 8N Parts Online
8n
BradWI
04-16-2007 18:58:23
My neighbor has an 8n and the three point will go up but won't go down unless the pressure line is cracked is there an easy fix stuck valve spool maybe? i'm an oliver guy so i don't know much about these any help would be appreciated thanks
Ray Wilson
04-17-2007 10:14:09
 Re: 8n in reply to BradWI, 04-16-2007 18:58:23
Brad,
Stupid question, maybe: you do have weight on the lift arms, right? If not, they will not go down right away, if at all. Stand on them.
Ray
souNdguy
04-17-2007 06:48:37
When you say 'pressure line cracked' what are you refering to. the only thing i can think of is perhaps the test port that is being removed to relieve pressure.
Take the dipstick cover off and see if the 3pt handle is making the valve move all the wy in and out of the pump.. help it by hand and make sure it is moving freely.
oil clean?
Soundguy
Ultradog MN
04-16-2007 21:55:01
Not to belittle the good folks here.
But them fellers on the N board will have you fixed up quick if you ask your question there.
