does not turn over when warmed up
Ben in wash.
04-20-2007 14:56:53
My ford 600 does not turnover when warmed up....Thanks .....Ben
GlenIdaho
04-22-2007 12:35:30
 Re: does not turn over when warmed up in reply to Ben in wash. , 04-20-2007 14:56:53
Ben; I'd also make sure that the engine is not overheating and the oil pressure is good. If they are ok then move on to the electrical problems.
Fred Van Hook
04-21-2007 15:20:09
I'd say the starter is dragging. Armature is swelling up and then rubs the field when warm. Seen it in cars and trucks. Probably have to get the starter rebuilt
GlenIdaho
04-20-2007 19:50:43
Ben; Can you provide some more information. What do you mean by "it won't turn over"? Do you mean the engine won't turn or there is no power to the starter? Provide as much detail as you can and you'll get some good help.
Ben in wash
04-21-2007 14:54:41
 Re: does not turn over when warmed up in reply to GlenIdaho, 04-20-2007 19:50:43
when I start the engine in the morning it starts up fine. After it is warmed up totally then you shut it down for a few minutes then try to start it up again while it is still warm it acts like the battery is almost dead and the engine will not turn over..... Thanks .....Ben
Larry NCKS
04-21-2007 15:12:49
 Re: does not turn over when warmed up in reply to Ben in wash, 04-21-2007 14:54:41
Check your timing, your starter, your battery and wiring connections.
Larry NCKS
04-21-2007 09:22:24
I second that. Sure hope my tractors don't turn over at all :-)
