 Hi All, Hopefully someone can offer some advise about the wiring for my cut-out on my generator. Basically I have the original generator for my carrier, along with a cutout mounted on it as per the original. There are two wires that come from the generator...one is the field wire and one is the armature wire. I attach the armature wire to the G location on the cutout. The field wire I put to ground. The two wires from the carrier...the red wire in my photo connects to the Ammeter , the blue wire goes to the switch board on the dash, It controlls the lights etc.. My confusion is...which wire goes where on the cutout/generator? I can't seem to get the battery charging! Below is a photo of my set up... Hi All, Hopefully someone can offer some advise about the wiring for my cut-out on my generator. Basically I have the original generator for my carrier, along with a cutout mounted on it as per the original. There are two wires that come from the generator...one is the field wire and one is the armature wire. I attach the armature wire to the G location on the cutout. The field wire I put to ground. The two wires from the carrier...the red wire in my photo connects to the Ammeter , the blue wire goes to the switch board, terminal "P" My confusion is...which wire goes where on the cutout? [IMG]http://i138.photobucket.com/albums/q243/Angelswithdirtyfaces1944/Generator001.jpg[/IMG]
