Order Ford 2000 Parts Online
3 cylinder 2000 fuel problem
Blue Horse
04-25-2007 05:43:30
I have a late 60's 2000 with loader. I noticed when blading snow in March that the engine would hesitate a lot when pulling the throttle. Yesterday I was using the tractor to get rocks off of a field....after about an hour of this (a lot of idling) the engine wanted to stall out when I engaged the clutch to go forward (in a low gear). Also backfired severely a few times. I bought the tractor from a dealer last summer, who had tuned-up the tractor before delivery. Any theories as to where my trouble may lie?
Blue Horse
04-26-2007 06:02:51
 Re: 3 cylinder 2000 fuel problem in reply to Blue Horse, 04-25-2007 05:43:30
Thanks for the insights, gentlemen. On the subject of the Holley carburetor....is an improved model available for the 2000 three-cylinder, or at least a new one that hopefully would remedy these problems?
Dean
04-25-2007 15:27:41
Blue:
The Holly carb used on Ford 3 cylinder gas tractors has a vacuum operated accelerator pump inside. Aside from being a wearing element in the die cast carburetor body, the pump makes the carburetor sensitive to vacuum related problems. Hesitation upon acceleration is a prime symptom of accelerator pump problems.
These tractors also have both mechanical and vacuum spark advance mechanisms, both of which will affect engine vacuum. Thus static timing, mechanical advance problems (common) and vacuum advance servo failure (very common) will affect operation of the accelerator pump.
Further complicating this situation: There is more than one version of these carburetors and overhauling a Holly carburetor with the wrong carb kit (again common) may render some carburetor circuits inoperative due to gasket mismatch.
Finally, these carburetors are very sensitive to float level due to the accelerator pump, and the die cast carburetor body is prone to wear around the float pivot pin due to engine vibration. This makes proper float adjustment effectively impossible.
All of these issues have contributed to the bad reputation earned by the Holly carburetors as used on the 3 cylinder Ford gas tractors.
The Holly carburetor works well on the 3 cylinder tractors if everything is right but after all of these years that is ususually not the case.
Good luck.
Dean
souNdguy
04-25-2007 10:54:59
Sounds like classic 'stumbling' when a load is applie dit sputters a bit then recovers.
Prime causes can be too lean of a mainjet setting.. or a partially clogged mainjet / fuel delivery system.. including float needle/seat.
See if a hair of choke helps next chance you get.. if it does, screw your main jet all the way in, count the turns and back it back out.. sometimes that disloges junk. I've also pulle dmine all the way out, and removed bowl drail and fuel inlet and used carb cleaner spray can and 'backflushed' the system with good results.
Reinstall jet and adjust for good power, no stumbling.. and no 'rich' black smoke out the exhaust.
Soundguy
