Loader
Jay Texas
04-25-2007 08:57:29
third party image
Does anyone recognise this wagner loader? I need to find out how the hydraulics hookup and if it will fit a ford 800
jr150hp
04-26-2007 04:55:15
 Re: Loader in reply to Jay Texas , 04-25-2007 08:57:29
i've really have a lot of research done on wagners you have a wm2 or wm3 i have a manual on them let me know whats up maybe i can help JR.
jr150hp
04-26-2007 05:02:37
 Re: Loader in reply to jr150hp, 04-26-2007 04:55:15
it will fit and i found all the info in the bits and pieces section in here just put in wagner loader in the serch lots of info and how to make the brackets even a cad drawing to make the front bracket JR.
Jay TExas
04-26-2007 07:00:17
 Re: Loader in reply to jr150hp, 04-26-2007 05:02:37
How does this loader hookup? There is not front pump on this. The loader that i have just has a valve on it no lever. It still has the original wagner cylinders the cylinders only have one port so i don't think that there is no relief. Im am just puzzled as to where it hooks up?
awhtx
04-26-2007 07:32:36
 Loader hookup in reply to Jay TExas , 04-26-2007 07:00:17
You have a couple of choices where to hook it up. If it has a spool valve with "In"and "Out" ports you will need to get an adapter plate from Tisco that goes between the lift cover and the accesory plate which is located in front of the tractor's seat. This adapter plate has "Pressure" and "Return" ports in it.
If your loader does not have a spool valve on it you can hook the hose directly to the accesory plate. You will then need to chain down the lift arms on your 3PH and use the lift control lever to raise and lower your FEL.
The cylinders only have one port because they are single acting cylinders. Hydraulic pressure extends the cylinder (raises the FEL) and the weight of the loader collapses the cylinder (lowers the FEL) when the hydraulic pressure is removed.
Jay Texas
04-26-2007 07:51:29
 Re: Loader hookup in reply to awhtx, 04-26-2007 07:32:36
What is recommended? I don't wnat to wear something prematurely but i also need to keep in mind how much any solution might cost. ie front pump vs the solutions you detailed. I do not have the set up infront of the seat that you mentioned and only have an open and close valve on the hydralic line.
awhtx
04-27-2007 12:29:27
 Re: Loader hookup in reply to Jay Texas , 04-26-2007 07:51:29
If you have an 800/801 it has the accesory plate in front of the seat. It is about 3" X 5" and is held to the lift cover with 5 bolts. There is a pipe plug screwed into the middle of it. Remove this plug and attach your loader hose in it's place. Chain down your lift arms (this will divert hydraulic pressure from the lift cylinder to the accesory plate) and use the lift control lever to raise and lower your FEL.
The only reason the accesory plate would be missing would be because someone has installed a spool valve in it's place. If this is your situation then you are in luck. Just hook your loader to the spool valve and use it to raise and lower.
murn ga
04-25-2007 09:34:46
 Is this it Jay? in reply to Jay Texas , 04-25-2007 08:57:29
third party image
Can't help you with your question,sorry.
Jay Texas
04-25-2007 13:34:52
 Re: Is this it Jay? YES in reply to murn ga, 04-25-2007 09:34:46
Yes that is the loader
Jay Texas
04-25-2007 09:04:40
 link http://www.tractorshed.com/contents/tpic340.h in reply to Jay Texas , 04-25-2007 08:57:29
The above link should take you to the picture it is on the archive section of this site.
Jay Texas
04-25-2007 09:00:06
 Re: Loader picture link in reply to Jay Texas , 04-25-2007 08:57:29
I new at this and hope this link works it didn't on the first email
