Order Ford 4000 Parts Online
Ford 4000 SU 1976 Value
30 Pointer
05-01-2007 13:37:05
My friend is looking to buy his neighbors tractor for food plots, etc It is a Ford 4000 SU (1976). He is looking to get $6000.00 for it. The tractor has a loader and wheel weights and is very clean. The only thing wrong is the PTO is always running. Can the PTO be fixed? How much? Is the tractor worth $6000 and what is the HP? Is this model a diesel?
Dean
05-01-2007 15:13:40
 Re: Ford 4000 SU 1976 Value in reply to 30 Pointer, 05-01-2007 13:37:05
30:
Without seeing the tractor I cannot provide much guidance but will say that I have been looking for a good late model 4000 SU diesel for some time. If it is in good condition, the price sounds reasonable.
Dean
RodInNS
05-01-2007 14:01:43
If it's actually a '76, then it's a 4600. The 4000 production ended in late 1975. The UNIT code off the ID tag will determine the production date.
Regardless, if the PTO is likely to turn on both when the oil is cold, but it should stop after it warms up. If it continues to turn, then there is either a brake problem, a pressure problem to the brake, or warped clutches. If the clutches are warped, you will not turn the shaft by hand when the engine is off.
What's it worth? I dunno. If everything is in workign order, it's clean and straight, and has good tires.... it's probably worth the 6 grand. With unknown PTO problems you could be looking at a grand to do a rear split and fix it... The HP was rated at 52 PTO, and the 4000 was available in both gas and diesel... but by that time gas was getting rare.
Rod
souNdguy
05-02-2007 11:36:31
 Re: Ford 4000 SU 1976 Value in reply to RodInNS, 05-01-2007 14:01:43
Did the late SU models still have the weak sister axle/ if so.. he needs to check it out due to the laoder.. etc..
Soundguy
RodInNS
05-02-2007 14:38:55
 Re: Ford 4000 SU 1976 Value in reply to souNdguy, 05-02-2007 11:36:31
Yes. That's what the SU was all about.... that damn axle. You're right to suggest checking it.
Rod
