ford fuel filter gaskets
bjr
05-02-2007 06:34:52
I replaced the fuel filter on a old 4000D with the 4 cyl. engine. I bought a Hastings filter supposed to be exact replacement. This is the type of fuel filter that has a top cover with a bleed screw on it. Well none of the Hasting gaskets fit. They were to large. I had reuse old gaskets from old filter. It was almost dark and I don't see to good anyways and it was miserable tryin' to get the gaskets to seal. Is there a replacement after market spinon type fuel filter head that a man could get and mount somewhere's accessable? I was thinkin' like the older Cummins engine spin on filter. bjr
awhtx
05-02-2007 07:52:36
 Re: ford fuel filter gaskets in reply to bjr, 05-02-2007 06:34:52
I have an 861D (same engine as your 4000D) and I replaced the fuel filter with a Wix. I'm not at home so I don't have the Wix number but I didn't have any problems installing it.
bfloyd4445
05-02-2007 07:03:37
I had the same problem with a 1975 2000D. Seems there are a couple of diferent fuel filter assemblies used and after market companies don't diferentiate between them. I ended up taking the old one into my NH dealer and matching it up. Good luck
RickB
05-02-2007 09:26:23
 Re: ford fuel filter gaskets in reply to bfloyd4445, 05-02-2007 07:03:37
A 4 cylinder 4000D and a 3 cylinder 2000D do not use the same fuel filter. Similar, with the same type mickey mouse gaskets, but not the same. Perhaps the original poster has a filter for a later 4000 which would use the same filter as the 3 cyl 2000 & 3000.
