Order Ford 841 Parts Online
Loader problem for my ford 841
30 Pointer
05-02-2007 14:24:36
My loader drops fast when lowering. It works nice and slow on the way up and when tilting the bucket. When I lower the arms you have to be so so careful. Is there away I can adjust? or replace a part to correct? My loader is a 19-702
jr150hp
05-05-2007 07:19:28
 Re: Loader problem for my ford 841 in reply to 30 Pointer, 05-02-2007 14:24:36
if you do have 2way cyclinders it might be a spool valve problem might have to rebuild the spools there not as bad as it might sounD JR.
old
05-02-2007 14:56:58
Sounds like you have one way cylinders on it and if so yep thats a common problem. They make a restrictor valve which can be put in to slow it down some. I don't know how well they work I just know they are made. Thats why I love 2 way hyds you can control them better plus you have power down so you don't need a jack to change a front tire.
