FORD 276 bi-directional tractor,
Bob Plumadore
05-03-2007 14:29:38
I posted this to the crawler and dozer discussion earlier.I need a little help.. I am a CAT maechanic, I do a little work on other things when I have to. Problem I am working on a FORD bi-directional tractor, 276, vintage 1988. It has a Cumings 4BT 3.9 Diesel engine. It acts as if it is out of fuel. An electric fuel pump has been added. It has not helped. it will run about 3 minutes at a time then the fuel flow stops. a dealer,s mechanic has replaced all the injectors and the tractor has not ran good since.
