Order Ford 2000 Parts Online
Clutch adjustment Ford 2000D
Bob Goss
10-25-2001 19:36:07
What's the correct way to adjust a clutch on a Ford 2000D Industrial Tractor? I had noticed a small adjustment stop screw with a locking nut on the swing arm (if that’s what its called) by the bell housing connected to an adjustment rod and foot pedal assembly... Does this screw assembly adjust the clutch engagement? Also how much play should the clutch pedal have before engagement?
