fuel leak
61 uni
05-10-2007 19:44:00
i've got a leak where the kill switch wire goes to the injector pump. Ive heard there is an o-ring there. How do I fix this leak. BTW it is a 71 model 3000 with a CAV pump.
RodInNS
05-11-2007 19:17:48
 Re: fuel leak in reply to 61 uni, 05-10-2007 19:44:00
You can remove the cover on the pump... which I find easier to do on a bench than on the tractor.... and you've got to watch the shutoff bar under the cover, and the location of the govenor spring because there is several combinations of holes for it's location.... but that's the gist of it.
Rod
