Order Ford NAA Parts Online
NAA -Trans
BK- Penna
05-12-2007 08:51:56
Naa-- No 2 speed transmissions. Right ?
Jim.UT
05-14-2007 14:20:29
 Re: NAA -Trans in reply to BK- Penna, 05-12-2007 08:51:56
As old said, all NAA's came from the factory with a 4 speed transmission. However, some have had auxilliary transmissions installed after the fact, either as a dealer installed option or an owner modification. Sometimes more than one aux tranny was installed. I have an NAA on my property now that has the factory 4 speed plus a Sherman combination Hi/Lo plus a Howard gear reduction transmission. Thats 4 (original trans) x 3 (Sherman) x 2 (Howard) = 24 total forward speeds and 6 reverse speeds.
old
05-12-2007 10:37:33
Are you talking about the one that came on it when new or are you talking about the dealer installed trannys like sherman etc.? If your asking about the sherman and if they could have one yes they could have a good number of differant ones installed in them. So you could have just the normal 4 speeds or you could also have 8 or 12 speeds also plus a few other set ups
