ford 871 sos trouble
leon abbott
05-14-2007 12:44:23
my 871 willnot move forward or back. 3point does not lift either. wondering if bad hydro pump could cause both problems? thanks fo any reply. leon
RICKWI
05-14-2007 16:01:39
 Re: ford 871 sos trouble in reply to leon abbott, 05-14-2007 12:44:23
Does the PTO shaft turn?
Larry NCKS
05-14-2007 14:34:45
The Canadian is correct. Have you checked the traction disconnect behind the tranny. If this has popped out you'll have no propulsion drive.
RodInNS
05-14-2007 14:04:08
I would suspect the lack of transmission movement could be the torque limiting clutch, or an input shaft problem... or even the traction disconnect at the rear of the transmission.
The hydraulic problem is likely a separate issue. If I'm not mistaken, the hydraulics on that tractor are sourced from a different compartment, and the pump is engine driven... so it should be a different issue entirely. That could be something as simple as the pump having lost it's prime, or a lack of oil.... or the unloading valve hanging up.... and so on.
Rod
bjr
05-14-2007 13:42:40
 Torque limit clutch? in reply to leon abbott, 05-14-2007 12:44:23
My old 4000D (like a 871)had a busted torque limit clucth plate. Actually it stripped out the rivets on the hub. This is like a small clutch that goes on the flywheel so you would have to split the tractor to fix it. When I was looking for a good used one, as I couldn't get new. I found out there were different splines. So if you have this problem just count splines and measure the diameter. I found one from Draper Tractor in WA. state. Cost $130,I think. bjr
Capern
05-14-2007 13:32:42
Sounds like you have a broken input shaft.
